180sx - 240sx Lazzy Eyes Ghetto And Buy Able
mario00013
Active Member
hey every one whats up
i was just thinking about some thing i was going to do to my car (sleepy eyes)
i dont wont the ghetto re-wireing junk with the switches mounted under the hood + the head lights might be more open on the left or right
so........ I searched a controller
I found a PIVOT Headlight pop-up controller it workes good and it's mountable in the car and looks good and makes the lights go up at the same time
THIS IS HOW TO DO THE RE-WIREING FOR THE GHETTO WAY
Well, you read the title, so here it is:
Approx install time: 1/2 hour (I took my time)
Materials:
2 Single Pole Single Throw (SPST) switches
Minimum of 6 EACH of Male and Female spade connectors (get a pack of each)
16-18 gauge wire (length varies on where you mount your switches)
NOTE: If you've done the "snip the brown wire for sleepy eyes" mod, you need to reconnect that wire first. This mod enables separate control of motors and lights.
This is the result: SLEEPY EYES
First thing, find this relay box:
Then find this relay:
Unplug it and put it belly up in the open spot a lil to the left so you can see the prongs.
Make 4 wires like the pic below about 6" long. Each wire should have 1 male and 1 female spade connector. Also make 4 wires long enough to route from the relay box to wherever you'd like to control the lights from (I went into the cabin for convenience's sake, through the grommet for the hood release cable). The second set of four wires should consist of 2 wires with male on one end and your choice of connection to a switch on the other end and 2 wires with female on one end and switch connection on the other. I just soldered to the switch contacts.
The first set of 4 should look like this:
Ok, now picture your relay and relay socket as follows:
Now numbered for convenience and lack of headache:
Ok, now follow with me here. This is where it will get confusing if you don't keep up. Connect 1, 3, 4, and 6 with the 4 small wires. Prongs 2 and 5 are the ones that will be switched. Connect a male/switch wire to socket #2, then to a switch, then connect a female/switch wire to the switch, then out to relay prong #2. Basically now you have a long, switched prong 2 to socket 2 wire. Make sense? Good. Do the same for 5.
Here, you can see a socket with five of the six connections in (the open spot was left there on purpose for a better view):
SORRY NO PIC I CANT UPLOADE THEM
And here's the relay side, in its new spot, again with one wire off for emphasis:
Close up the relay box, with your switched wires hanging out (or mounted in the car, or in the relay box)
Now for the fun part, which is confusing at first, but makes total sense once you try it.
Make sure your lights are turned off and the flip-ups are closed.
Turn both your new switches on and observe how when they are on, the lights and flip-ups work just like normal.
Make sure your lights are turned off and the flip-ups are closed again.
Turn both your switches off. Turn your headlights on. Notice that they are lit, but closed. Now, if you flick one of the switches up really quick (for just a split second), your headlights will rachet upwards. Kinda like the brown wire method, but this one controls them on the way up. Flick the switch til you get the desired height. Leave your switches the way they are and turn your headlights on and off. Now only the lights go on and off, but your flip-ups stay still. How cool. If you want to reset to normal, at any time, just flick both switches on.
I.
OK I WONT TO KNOW HOW TO INSTALL THE PIVOT Headlight pop-up controller AND ALL THAT JUNK DOES ANY ONE KNOW HO TO AND PUT PICS UP I NEED TO KNOW WHAT YOU ARE TALKING ABOUT
short or sketch !!!!!!!!!
LOL every one told me that but cutting it might short it later on wich is bad and make the lights sketch up and dawn by them self my brother had done it the way you'r talking about and his switch was verry sensitive it would sketch alot
YES !!!! IM REALY FROM CANADA and i dont wear a mounti suit and i dont drink maple suripe and all that other stuff people think canadian's do er dont
yea i know all that stuff, but hows aboot you go to a junk yard for me and get me some of those fog lights for the s13 from over there!
please and thanks!
i could try but alot of nissan's in junk yards are slim they dont have nissan's there good cars projects and stuff i havent ever seen one in a junk yard only 1 or 2 and they where in serious crashes and where striped right dawn to the dash and the stock shifter nob i dont live in a veryy good place for junk yards ether i moved this year and dont know Bantford well and im oly 16 lol i know cars but people just think of me as some stupid young kid or what ever lol WHAT EVERRRRRRR!!!!!!!!!!
i could check some junk yards IF i get the time
GOD I HAVE TO TAKE THE BUSSSSSSSSSS AGAIN lol aw man LOL
Damn dude, it'll be awesome if you can get some S13 fogs...meh, just cut the brown wire and cap/tape the ends, you wont have a problem....ever.
