240sx 91 od1 to a 96 od2 swamp help
lamaravia69
how can i get a 96 ka engine od2(s14 engine) to work on a 91 od1 240sx..
any info on how ? harness? sensors ? help?:werd:?
please for gods sackes fucking search uses fucking google please!!!!!
in order to use a s14(obd2) motor in a s13(obd1) chassis u need todo the following-
use the s13 intake manifold on the s14 motor
s13 distributor
s13 harness
s13 maf
s13 ecu
done!
s13 distributor
s13 harness
s13 maf
s13 ecu
done!
you dont need the s13 intake many, just the TB with the TPS.
i got a 98 intake many in my 89. :bigthumbu
what you do need is the exhaust cus the 95 and up is 4 to 1. triangle chape. but the 91-94 is 4 to 2. so unless you have the 96 exhaust and dawn pipe and cat. then you need the s13 one.
i got 98 everything. intake and exhaust down to the cat WOOT>
when i did my swap, i swapped distributors and throttle bodies. oh, and the a/c compressor brackets are different too. i blocked the egr and used an aftermarket header. there are going to be some electrical plugs that will not get plugged in, but mines been like that for months with no check engine light and it runs perfect.
sick info everyone.. im going to pick up a s13 shell tomarrow, and i currently have a 96 engine/tranny so i figured ill drop it in it. thanks for clearing me up guys. when i start working on it if i run into anything weird ill be back on here lol
