5 Lug swap
South_Coast
I have a S14 and S13. Is it possible to swap the Diff and front knuckles from the S14 to the S13. And will the S13 parts fit on the S14? What do I need to swap for the front 5 lug? I hear it's just the knuckle, but I also hear you need to swap the lowwer arm to or atleast put a S14 ball joint on the S13 arm. I just dont know.
Thanks for reading and any input.
Nick
You can just usetheball joints or you could get the lca's tie rods/ knuckes, and rotors, you can keepthe pads if you want, and if your hubs needs bearings, I got new ones forsale
If you don't care about the s14 take the whole flca and swap it over. You also can swap the whole knuckle too but when it comes to the bolts for the coils they are a different size between the s13 and s14. The s14 bolts are 2mm larger so when you go to install you s13 coils you will have to drill them out some to fit the larger diameter bolt into it. I was not a fan of doing that so I just got the conversion hubs. Everything else is the same the rear is just the hubs that need to be swaped over. Brakes and all can be kept on there original car especially the rear brakes as the s13 brackets are a little different
Oh and the diff can be done too just gotta change the covers cause s13 4bolts s14 2bolts
