a/c wiring in an sr
alibaba
Ali Nassar
k guys i have an s13 red top sr in my s14,
i got the compressor on but it needs to be wired up still, does any one know where i can find any info????
I have no idea, I would guess then try to figure it out.
there should be a connector that plugs into the ka a\c compressor, if you have the sr20 one, then connect it to those wires. dont mix up power and grounds, check w\ test light first.
I am so fucking tired, 12am every night since sunday at the shop working on my car after work just so i can go drifting sunday. purchased another engine, swapped intake and exhuast manifolds onto it, oil pan, crank pulley w\ trigger wheel, flywheel clutch transmission. Put everything back in. and holy shit it runs. I might be going drifting. maybe. so tired. along with sanding my quarter panel and priming it.
