Yes camber effects toe so get toe arms and as for traction rods here's my theory. When you slam your car you obviously get adjustable rear upper camber arms to bring your camber back into spec. Now what happens is when you elongate the arm soo much it creates bump steer, by using traction rods you can equally distribute both arms lengths to eliminate this. While you're there I'd change it, plus there stronger that stock.
