hachi
DATE CHANGED!! NOW APRIL 18th!!
April 18th Drift session Big track at countyline 2nd left!!
and we need atleast 25 pre regs to run the event. I will start a drivers list when I start receiving payments.
NEWS FLASH!!!!!!!!!!!!!!! There will be a tire changer at this event!! Thanks to Jackson Performance.
If you have any questions call me 954-557-2430 I won't be able to answer the phone mon <--> thurs after 3pm so leave a message
Gates open: 11AM
Drifting starts: 12PM
Event ends: 5:30PM
Cost: $55 to Drift, $15 to Spectate, $10 to Ridealong
Tech requirements:
Guidelines:
1. DO AS I SAY!!
Drivers list;
1. Robert Matias
2. Hector Rubio
3. Justin Punancy
4. Sean Mcqueen
5. JAVIER FIGUEROA
6. Kevin Phillips
7. Ali Nassar
8. Rod Becker
9. Randy B
10.Anthony B
11.Andrew Bowman
12.Courtney Squire
13.Jerry Montero
14.Alexander Gonzalez
15.Noah Pribyl
16. Jonathan Bowerman
17. Daniel Ramirez
18. Josh Lochner
19. Miles Hirschel
20. Bryant "sweet nips" Bustamante
21. Rafael Wiltz
22. Mark Congrains
23. Jimmy "Jimbo Slice" Constantelos
24. Sal Sued
25. roberto victoria
26. Matthew Beesley
27. Chris Kastner
28. Owen Conrad Pearson
29. Christopher A Suan
30. Jeremy Smith
Media list;
1. Patrick Konior
2. Zack Hughes
3. Robert Kauffman
4. Jose Cruz
5. Korey Chang
6. Ellejah Becker
Gates open: 11AM
Event ends: 5:30PM
Tech requirements:
Guidelines:
1. DO AS I SAY!!
[size=+2]CONTACT BEN FOR MEDIA PASSES TO THIS EVENT!![/size]
Drivers list;
1. Robert Matias
2. Hector Rubio
3. Justin Punancy
4. Sean Mcqueen
5. JAVIER FIGUEROA
6. Kevin Phillips
7. Ali Nassar
8. Rod Becker
9. Randy B
10.Anthony B
11.Andrew Bowman
12.Courtney Squire
13.Jerry Montero
15.Noah Pribyl
17. Daniel Ramirez
18. Josh Lochner
19. Miles Hirschel
21. Rafael Wiltz
22. Mark Congrains
24. Sal Sued
26. Matthew Beesley
27. Chris Kastner
30. Jeremy Smith
Media list;
1. Patrick Konior
2. Zack Hughes
3. Robert Kauffman
4. Jose Cruz
5. Korey Chang
6. Ellejah Becker
