Autometer gauges install
gugarios
Brazil-S14
Im trying to install oil pressure gauge and water temp gauge on my sr20det blacktop.
For the oil pressure sensor, what is the best adapter.
"T" fitting or the greddy sandwich block adapter.Have any of you guys used the greddy, fits perfect? need any modi?
http://www.nissport.com/catalog/product.asp?ProductCode=NS-2100&EquipmentType=Products
http://www.frsport.com/Greddy-12002801-Oil-Filter-Sandwich-Block-Adapter_p_1241.html
And for the water temp, I was thinking in use a hose adapter. What you guys think?
Thanks....
oil pressure- go to home depot/lowes/ murrys speed and cutoms
u need a 1/8npt male to male fitting and also a 1/8th npt Female "T" fitting.
screw the male to male fitting in to the "T" fitting. remove the oem stock oil pressure sensor(sensor located next to the oil filter), then install the other side of the fitting in to where the stock sensor was installed,now u can screw ur aftermarket guage sensor in to one side of the "T" and u can screw the stock oem sensor in to the other side of the "T"
-make sure u use plumber's teflon tape on all the fittings, or they will leak oil.
start car check for leaks and oil pressure!!!!!!!!!
- water temp sensor can be installed in to the upper rad hose buy buying a rad. hose "T"
http://www.frsport.com/Greddy-Radiator-Hose-Water-Temp-Sensor-Adapter-30mm-to-40mm_p_9267.html
-side note-autometer sensors must be grounded for them to work!
