Drifter_85
Ok so I'm on my 4th battery now. So I put my first battery in and it worked fine for like two days and then my starter would just click but if I kept turning the key if would eventually start. I thought it was my starter so I got my starter rebuilt and it didn't help. Then I started having to jump it, I took my battery to AutoZone a d got it recharged then they tested it and it was bad. They replaced it and everything was fine for a couple days and then It started All over again. Brought it back they charged it and tested it andit was bad. They replaced it and this time I put it in but when I would park I would disconnect the nagitive terminal and it worked for about 2 weeks and me and my brother checked for amp draws and we found nothing, when the key is off there is no draw from the battery. So I kept the battery connected and 3 days later the battery was dead. I took it to AutoZone they chArged it and tested it and it was bad.. I asked the clerk if I could exchange it for a miata battery and they let me. So today I moved the battery back up front and I used the extra 4 gauge wire ihad to add more grounds from the
Motor to chasis and then I went to start my car and the battery was dead.. I went back to AutoZone but they were closed so ihave to wait till tomorrow to check the batt but now I'm very frustrated so I want everyones opintion on WTF this could be! Could there be a problem in the alternator? Can I check without buy another one and wasting more money? When I put my tester on the battery when it's running it reads 14.1 and when I turn the car off it reads 11.7
