RedOctoberS13
ok heres my problem, i changed my front calipers but didnt tighten one of the banjo bolts tight so i started leaking brake fluid and im pretty sure i got air in the lines now. i will need to bleed the brakes asap but the problem is when i turned on my car and started pumping the brakes the idle would start dropping and dropping after every pump until the car almost stalled out. i would stop and the car would go back to normal idle then when i pressed the brakes again the same thing would happen. bad booster? vaccum leak??
