brakes
Not so pricey? What's your budget? Are you looking to replace your stock setup with big brakes? You can get hawk pads and slotted rotors on your stock calipers for a pretty decent setup. Or go with 300zx brakes with upgraded pads / rotors. It all depends on how much you're actually willing to spend.
thats expensive ass hell.
Dude go Q45 or j30 in the front, and just upgrade to better rotors and pads in the rear.
any brake upgrade for the rear such as...j30,q45,z32,m30,r32,r33,r34 have Drum ebrakes. wich are a pain cus you need to redo the ebrake line or maybe buy custom conversion lines.... plus the drum pads are more expensive....
im going to run q45 in the front and just sloted rotors with nice pads in the back.
also the proper procedure when upgrading to big ass brakes is upgrading the brake booster to like a 300zx. so yeah more work and more money,.
hope that helps. and next time search in www.240sx.org
:bigthumbu
are you running larger wheels? or stock wheels or other 15's?
nah i got the stock s13 se's on but my brakes are horrible
my budget is like 200
200 will not get u anywhere if ur gonna run z32 calipers plus ur gonna need spacers if u plan to run z32 brakes with stock s13se
is it really necesary to change t0 the 300zx brake master cylinder when you change the front calipers to 300zx? mines got a little soft but i think bleeding with solve it or i need to go all the way with new master cylinder ? :p
also the proper procedure when upgrading to big ass brakes is upgrading the brake booster to like a 300zx. so yeah more work and more money.
Its not the booster it is the Master Brake Cylinder - and there is a guy on Zilvia selling the 17/16 MBC for that conversion with the added fitting for our cars
j30 or q45 calipers 15$ each at jyard. new pads like 20-30$ rotors 15$ea brand new at discount auto. contact someone that can redrill your rotors to 4lug. like 30$. 130$ bigger brakes. and they use the stock brake lines.
if you need a number for someone to redrill rotors PM me and i'll give you a guy in Miramar and 441 area.
