cluster gauges dont work, only lights up?
my cluster gauges dont work, only lights up, and after a while it blinks on and off while im driving, and then stops working.(gas light is only on) and wen i try to put my turn signals, they dont work.>..... if anyone can help me out wit dis issue, i'd appreciate it!so i can finally go to work happy!:driving:
do u have a sr swap?
check the brown or white plug behind glovebox to the right that is the cluster plug
its a ka 5 speed swap..i already found problem to the turn signals, but cluster still not working. ill check that plug u were talkin about. is it the plug that connects to the ecu? cuz that plug is on.
i put a dual cam one on, it worked last time but now it doesnt.i dropped one time maybe that can be the problem. but it can be also that i didnt wire up the plug right. i need a dual cam and single cam dash wiring diagram to make sure its right. do u or anyone have by anychance? thanks
uh its color to color..just maybe an extra blk which is ground
if u fix those wires and it doesnt werk maybe the cluster broke
