cluster wont shut off after ign is off
ehh the same thing happens to me somtimes, the way i get it off completely is turning the car back on and turning it off. i have no clue either
funny shit is when i take the meter fuse off .then the cluster turns off .plug it back in turn the car on turn it off same shit happens agin i was thinking about puting a on and off switch on the fuse what u think
it sounds like the relay that give the meter circuit power has gotten wet ie.stuck on..look for that relay and check it for water damage...like rust underplastic cover
well if it stays on even after you unplug the ignition then it sounds like a stuck relay. find the relay that powers the gauge. if you have another relay that is of the same type for something else do a quick check and switch them then see if it stays on after you turn it off.
same happens to my vert.. the egi relay starts to vibrate and i take it off and put a new one on and it dose the same. so i just took off the fuse..
