coolant flush the RIGHT WAY!
Ok, so i've done my research and read about 4 different ways on how to flush an sr20det. I would like your opinions on the MOST effective way to flush dis bish... It's sr20det with mishimoto rad.
Stick a hose in it from the top and then open up the bottom of the rad. once it's all out put new fluids in, start car, put more, done. << This is at home way. Different at dealership.
Its very simple homie.
The bottom right side of your radiator there a drain plug unbolt it and it will drain the fluids all out. Before that take off the radiator cap.
You can either buy a flush system fluid from a local parts place, or you can do as Shane said threw the radiator cap hole put in a hose and just let the water run for awhile.
After your satisfied with the system flush fill it back up with 50/50 or all water or w.e. you want. I'd use distilled water so it won't get all rusted inside.
For what your doing you dont need to do that. When you fill it up turn on the car and let it warm up so you can know when it will be topped off.
k thanks will do. will that also git rid of the water that's already in da motor tho?
