dam coolant
Drez
Cuban Drifter
now there are a few coolant lines that run under the intake mani... well i thought one of them had a crack/hole. well i took off all the lines i can see and replace 2 of i believe 3 with new ones... well guess what it still leaks... now its right above the alt so i get kind of worried cause i dont think water/coolant leaking on it can be good.... its really hard to tell exactly where its coming from because i never see it pour out... the few times i did it was steaming out/spraying right under the intake mani... the only thing i can think of is removing the whole intake mani.....
the whole thing is that there are a shitload of lines and things to remove.... anyone ever had this prob before....
also there is a real odd problem with my tail lights... when i hit the brakes the dash lights and the front parking lights turn on... you cant tell the dash lights turn on unless its night time.... its really dim... at night when i turn the head lights on the tail lights turn on but the lights are bright like if someone is holding the brake down... the center brake light is also lit..... i though it might be a blown fuse but i looked at the all... also changed the light bulbs though one might be going bad but nothing.... i dont think its the brake sensor thing behing the pedal cause like i said the brakes still work... even at night when i hit the brakes the brake light will get a little brighter... i dunno... ..
I have the same problem with the lights. Mkaes sure your grounds in the tail lights are good. After I tightened mine that problem went away. I think
