Flex A Lite Fans
Deuce40
I think one of my blades got bent somehow does anyone know how to fix it? :confused: My whole front end shakes when my fans kick on.. This can't be safe can it? Nothing happens it just shakes enough to notice. :mad:
Well when the fans kick on it starts shaking.. It's to dark to check right now but when I popped the hood earlier there was this little rubber hose in it that came off from the top of the fans and it was in the fans.. So I took it out and ever since then it started to shake
They have some plastic piece that go thru the radiator so thet Fans can hold in place are those on?
You mean those things that are on the corners? the 2 top ones are loose.. but is there a way they just snap in or something because i was trying to push it in but it doesnt do anything.. and when i turn it it just turns back to the same position
They are like pins that hold the Fans from moving back and forward. If you just have one and or if there loose that might be why is shakes.
yeah they are like square things that push in but i cant push them in it doesnt do anything.. and i can see if anything else is loose
