i swaped my intake manifold while the motor was out of the car so i wasnt that bad. one thing you do need to know is you will need to make a bracket for the throttle cable.
That's it, the cable bracket. I bought a piece of 90 degree bent aluminum from Ace, took measurements and drilled with a dremel. Its that easy. Just make sure the aluminum is thick enough so that it wont flex when you're at WOT.
the install is going to be with the engine out of the car....the bolting of the
manifold I'm sure to have no problems....
i just wanted to make sure I run the correct vaccum lines since
I have had the car without the engine for some time...and I'm afraid I'll be
missing or routing the wrong hoses
