Intercooler install
RTM240SX
I bought a front mount intercooler and it did not come with anything to bolt on to it. So my question is where is a good place to go to so I can get brackets welded to the aluminum intercooler in palm beach county?
depending on the intercooler, you can have tabs go from the bottom of the core or end tanks to the bottom of the lower radiator support.......... You could have aluminum angle welded to the end tanks and through bolt it to the frame rails if it is wide enough.
there are alot of different solutions, not one way is correct, just make sure that its pretty stable when its all said and done.
Velocity Factor, ask for Luigi.
