Manual Steering
mark_fox
So i've been reading around and i can't seem to find a manual steering rack for an S13. does anyone make them or to make manual steering do people just take the pump off and call it a day?
-Mark
all you do is remove the pump and lines and then loop the high pressure and low pressure lines together
That's fine but like slambar said, it really isn't like a manual rack. Not nearly as responsive and a manual rack is actually lighter to turn compared to a PS rack without a pump.
Yeah you have to take the PS rack apart, remove seals, drill some holes and shit. Basically you take everything out of it that makes it a power rack. Then lube it up and put it back together. Then it's a legit manual rack. I know for a fact there is a write-up with pics on rx7club for FC racks, but I'm not sure how many people do it with 240s. The reason people do it with FCs is because power racks have a quicker ratio than the manual racks do, so by de-powering a power rack, they now have a quick ratio manual rack.
^^ Yea it is the gearing. Manual racks have gearing made for a person to help turn, Power has gearing made for a pump to help turn. Less turns on the power means harder to turn by hand without assist.
yeah i understand that, i was more sayin de-powering the rack, but maken a "real" manual rack is a lot of work
