no clutch
hi the car is an s13 240sx no swap just sohc
i have no clutch pressure , i had a leak in slave cylinder so i replaced it , still nothing searched and found out i need to remove the loop ( aka damper ) done , but i still have nothing , no leaks any where else paddle drops to the floor like a fly , im wondering if its my master:chair:
thanks
yes maybe im doing it wrong , one person pumps holds and other opens and closes the valve like brakes , but it never gets firm no matter how many times u pump
try and pump the pedal was fast as you can and see if you get pressure in the pedal. if you do than pump fast, hold it down when you get pressure and crack the bleeder screw open. close screw and repeat. you can also try gravity bleeding the lines. if that doesnt do it then the only thing you have left is the master.
thanks for the help i got it the only way it worked was to pump and hold open close pull back up and repeat , just one pump at a time ,
