TurtleS14
whats the oil pressure supposed to be around if everythings normal on a KA
i did a little research and came up with this
"But you'll want want 15psi or more at idle and over 30psi once the rpms have gone past 3000. Those are for an engine that's already warmed up. If its cold, they will be ALOT higher. Don't use those numbers. However, if you have low oil pressure when cold, and the car has been running for more then 2 minutes, shut the car off and inspect the oil system. Hopefully its just low oil level."
when heated and im driving my oil pressure is around 50ish psi maybe a little higher or lower depending on gears and rpms. Idle its around 20-25ish??
