Power streering pump question
randyb
I just put an sr20 in to my sohc 240sx. I know that if i want to keep power steering i need to get the lines from a doch. My problem is that the swap came with a HICAS power steering pump. Do i need to get a sr power steering pump or could i use a ka or would i be able to use the hicas pump. Thanks for all your help.
you can use a KA pump if you use the SR pulley and tensioner bracket. call NAPA autoparts and get a 95-98 high pressure line for 240sx cuz it comes with the hardline you need too
You can use the KA pump or the Hicas pump.
If you use the Hicas pump you have to take it apart and take all the fins off the back part of it, then block the hole in the pump where the line runs into.
My friend Tom did that on his CA and it worked perfectly.
