quick question?????
nat is the anti theft system for the ignition, its the "smart key" bullshit if you will. there is a ring around the key hole in the dash that reads your key and then lets you start your car or not....
why the hell your asking though seems kinda odd
thanx and no im not stealing cars its that im most likely going to be buying a vq35de from an 04 to swap in my car, and for the vvt to work i need to have the bcm, nats, and ecm installed. otherwise it would have to be hardwired and that would also work but the vvt wouldnt work and that would cause me a 20 hp loss. so if i could find those parts for cheap then thats 20 hp more. not that it would matter in the car it going cuz it only weighs in about 2200 lbs. but i think if your going to spend the money might as well u know....
but anyways thanx again....
....and for the vvt to work i need to have the bcm, nats, and ecm installed. otherwise it would have to be hardwired and....
Well of course you'll need the Ecm installed, thats your engine control unit..... who's doing the swap for you?
