s13 auto nd manual brake pedals.
milkyninja
hey, can i use the sensors on my automatic brake pedal and use them on my 5 speed brake pedal? im doing 5 spd swap on my s13 hatch. thanks in advance for your input.
i think u just have to add the clutch pedal and change the auto brake pedal to a 5 speed pedal...this would be my guess im not really sure, thats wat they do on honda's lol =p
oh yeh if u just cut tha brake pedal then ur still using same sensors. k thx guys nd i can use auto sensors. if neone wants to stop by in boynton. military and gateway. i need help with getting flywheel and torque converter. i need soemone to jam a crow bar or something into crank pully. i have a breaker bar. so they dont spin. lmk thanks 561 634 1478
No you don't...
Grab the fucking engine/tranny, lay them on 2 tires (oil pan inside tire) and jam the wrench for the crank onto the tire so it doesn't spin anymore. Then with a braker bar remove flywheel bolts jesus! That or invest in some fucking air tools you dam jew.
<3
ohh god solo. you always seem to have something stuck up your butt. first off my car is on jacks and i dont have time to to drop motor. second air gun doesnt fit on the bolts on torque converter. i am gunna use a air gun on flywheel bolts. solow you are a sfl forum whore. gtfo of here.
Read a book...
oof, you're not even at the auto pilot bearing yet.. GL!
Try jamming something up between the torque converter and that flywheel, or chains..
Doing some pushups daily would help as well.
already got it off thanks. i used a flat head screwdriver nd put through bottom gusset nd jamed into edge of flywheel nd took tha 4 bolts off.
