S13 Electric Fan Clutch. How?
I Eliminated My A/c System And Want To Put The A/c Fan As The Cooling Fan So I Can Delete The One On The Water Pump Meanwile I Get The Altima Fan Clutch. I Know Theres More Than One Way To Do It But I Want The Fan To Start When I Turn The Ignition. How Do I Do This? If You Can Give Me A Link Or Website Where It Shows You Step By Step With Pics I Would Greatly Appreciate It. Thanks Dudes
??? I Dont Know Much About Electric. I Know I Have To Put The Black Cable From The Fan To A Ground But Idk What To Do With The Blue Cable.
ok that was kinda confusing but i was told that i coul just ground the black cable from the fan anywhere in the engine bay and conect the blue one to one of the cables coming out of the back of the ignition cylinder. but idk witch cable of the 5 that are out the back of the ignition it is.
no read toward the bottom
Pull the cover to the passenger side fuse box and locate the ac fan relay. Should be in the driver side front position. Now lift off the middle part of the fuse box so that you can get to the wiring underneath it. look for the wire coming out the bottom of the relay that is orange with a blue stripe. That's the one that goes to the ecu. If you ground it, you can watch your fan come on (if it's still connected, of course). Splice into the wire any way you like. Run a new wire from there to wherever you mount your temperature probe. Now one end of the probe is gonna be grounded (the body of it) and the other end (the blade connector on the top) is gonna be the one you want to connect to. Take your wire and connect it to the blade connector and tape it up good.
