sidewayzpimpn
to wire up an s13 with an s14 ka dohc the plug that comes off the sohc harness is right by the ecu right??? i just wanna make sure and were is that plug sopposed to be attached to the dohc harness..... is it located in the same spot.... i know they are color coated but do i have to cut one off the dohc harness to attach that sohc plug....jus need to clear it up.....
another thing does the drive shaft have to be unbolted or does it slide out....were is the easiest place to unbolt from????
and does the exhaust mani from the s14 dohc fit directly to the s13 exhaust pipin???
get bak wit some knowledge i heard this is were i can find it holla at ya boii
