S14 dirveshaft ?
madcowCONV
I have a s14 that i just did a 5spd conversion on and it's a non abs version. now here is my question the only diffrence between s14's with abs and those that don't have abs is the fact that abs cars have lsd right? so if i get a j30 lsd i can use the abs drive shaft right?
You can use an abs driveshaft - its just a little shorter but it works.
But yes, if the diff housing has an abs sensor, it will be a little longer and fit perfectly with the abs driveshaft.
