s14 sr20det A/C question
xtylerx
i have a 1995 s14 with a s14 sr20 swap. i have all the stock KA a/c lines. if i get an s14sr20 a/c compressor, will everything line up?
no. SR20det is JDM (RHD) your car is USDM (LHD) Lines are at opposite sides. You would have to custom make lines or buy a kit (I hear theirs some kit out there).
the lines on a ka are in the same place as an sr's. but the fittings on a 240sx were they bolt to the sr a/c comp are diff. if you were lucking enough to get the lines still connected to you compressor when you got you swap then all you have to do is take those and you stock lines on the chassis to a a/c shop and have the fittings put onto your lines.
i already ordered a sr compressor pretty cheap and thats on the way, once i get that, what left do i need to modify?
