stupid azz tranny problems.......
rollordie
Ok guys thanks for all the help in my other thread about slapping on the tranny on my s13......the tranny is on now.....yess....
But the rear tranny bracket isn't lining up up to the 4 holes on the bottom of the car.....y?
I looks like the engine is pushed forward 4 sum retarted reason?
Any info on this?
well on the trans bracket stick a screwdriver or a strong rod in one of the holes on the bracket and then twist the bracket so that the other end of the brace is aligned with the bolt hole, thread the bolt in and then do it to the otherside, with the two holes bolted up the others should line up to
yes the 5 speed and auto brackets are diffrent!!!!!!!!!!!!!!! are u kidding me!!!!!!!!!!!!!???????????!!!!!! come on do some resaerch!!!!!!!!!!!!!!!!now!!!!!!!!!!!!
Yeah....I thought about it a lond time ago.....but I had my old 5spd tranny on there with the automatic bracket......I guess that since I got the nismo mounts, and they make the engine sit higher......
well that might be it.....thanks
ill update
