Tein Flex*** S14** WTF!!!
Blurrbosi
So I get my tein flex's in.. I install em'... back goes in great...
I have 8.5 in. wide wheels in front with a 35 offset. Why is the effin shock hitting my wheel??? I got spacers to fix it... fist 3 then 5mm... still not working... So i put them together!!!! 8mm NOGO...
What the hell/?
I was loooking @ these but... 15mm..... seriously?
http://www.driftingperformance.com/p...37b a4e1668e9
Coilover clearance is one of the biggest drawbacks of high offset rims. Especially when you have to go as far as extended studs to work with 15mm+ spacing.
Its because on the factory strut, the lower spring perch sits above the wheel/tire. How do you have your coilovers adjusted? If your lower shock body is threaded up all the way (or as high as it can go) you're making clearance even more of an issue.
Naw... Its been adjusted back and forth... I just need to spend big bucks apparently. Thats if I dont like the spacers...
