water wetter vs. 50/50
  • Total voters
    24
sdeream
Parked...
aight so alot of ppl are telling me different things about whether i should fill my radiator with all water and a 12oz bottle of water watter and just putting 50/50 coolant and water and a 12 oz bottle of water wetter. wat do u guys think? keep in mind that while the water wetter is "supposed" to run the temp 28 degrees colder than the traditional 50/50 solution it also corrodes the radiator alot faster.:ugh:
wtf u view it but no post? 5 views no posts...
I never heard of water wetter corroding the radiator but rather the opposite. It WILL run cooler than straight water or 50/50. Antifreeze is not necessary in FL anyway.
holy crap. there is no option. distilled water and water wetter is the only way to go.
+1
nothing in the world has better convection properties then plain water. Coolant only raises the boiling point by about 5C which is trivial as long as you have a good pressurized system. water wetter allows the water to do what it does best while at the same time eliminating oxidation and corrosion
from personal experience i used 50/50 and water wetter, I start using it when I had my bike it used to almost overheat at the red ligth, but when I used both products the temperature always stayed at midle, also I used both in my car's and zero problems.
