Wiring electric fans!
rb_reds13
If anyone could help me with this I'd really appreciate it...I need to wire 2 12" electric fans. I' am supposed to wire 2 30 amp relays, one for each fan. The relays have 4 prongs... How do I wire them in. Also is there a specific kit or way that you guys did it. Thanks!
Hey, if you want...Thats cool. I'm going to try wiring the fans to a fuse then to my ac button...See how that works out...
Why dont you just hit up a auto parts place and get a temp. sensor the fans so after you set your desired temp. it automatically turns on the fan so you dont have to worry about flicking a switch when you get in your car and out your car.. Or wire them to the ignition so when you turn on the car they automatically turn on.
wire it like it came from the factory, get a fan switch and relays from a nissan that came with electric fans, thats what i would do. and i wouldnt trust one with a wire probe (aftermarket).
Should I wire up relays only if I run a temp switch? If I run the wires to my ac button should I still run a relay?
someone should post a diy with pics...that thread needs more post. I'd appreciate it, and I'm gonna make some too.
I can't find a diy with pics anywhere on the web...What should I use as a 12v source? Do I hook it up to the white fusebox wire? Where do you guys have them hooked up...I also need to find a 12v for my autometer gauges...My radio has no power so thats out of the question for now...Do I just wire my gauges to a 12v power supply coming off the ecu? Sorry for the gay questions...wirings not my thing.
dont touch the ecu wires unless you know what your doing or have some who does doing it for you. you can cause alot of damage and problems, best advice i can contribute to that. if your looking for a 12v source to light the gauges the best way i think you'd be to "t" of the headlight switch to an open slot in the fuse panel with its own seperate fuse, and comes on like it came from the factory. i thought i seen a diy for the fans i'll check.
