**CANCELLED** Dirty Drift **CANCELLED**
if my cars still running for this im so down i already got a set of truck tires to run LMAO
Well, I'm not real technically savvy. So No. Unless someone can tell me how to past the Google image into MS Paint. It doesn't seem to work for me.
Basically the course runs clockwise. The triangle you see has an inner and outer road. There is about 8 feet between the roads and a berm. So even though they look close it is very safe.
http://maps.google.com/maps?hl=en&ie=UTF8&ll=29.850434,-82.048259&spn=0.012134,0.015621&t=h&z=15
Coming from the far left on the road that is on top in the image. The triangle is formed by the road splitting off to the North, shaping out the point on the top of the triangle, then makes a U-turn and runs next to the road you were just on until it dumps you right next to where the road first split North. Then you make a left to the east and then make another u-Turn creating the bottom of the Triangle. Then there is a fast straight back to the pit area where you can rest or get back in the line to go again.
I left some of the hairpins out of the above description because they don't make out the overall shap (but you get the point) and we will be taking some of them out to make for more linkable corners. Don't worry, we are leaving a few in that will make you really drag out your line to hold the drift.
find the image in goggle or whatever and hit print screen then go into mspaint and hit control + v and it should paste the image into it
This is using the smoothest portion of the track; and, any more would just be to long.
Even though this shot is really out of date, you can kinda see; this area is also where the trees have been cleared and the ground is semi-smoothed if you do go off.
theres no way you could link all that LMAO thats manji from start to finish thats like a tank of gas for one run in my supra
No, you can't link the whole course; but, the long course is the best part. No long waits for short runs :bigthumbu
Linking the individule groups of corners is where the challenge/learning will be.
^i got more then enough power to link it its just how much gas will it take LMAO. my car in normal driving only gets 5-6 mpg while drifting i dunno maybe 2-3 on 93 octane
your car defiantly has the power its the nut behind the wheel that may have a problem linking it ;)
If you can link the whole thing with me in the car I will refund you some entry fee.
Is this a promise?
Then why the hell did you put that motor in if you cant afford to run it. Smart move.
Well don't complain then when its your fault you stuck in a motor that you can't afford to run.
