idle air control valve operates throught the computer, your idle flucutaes with other factors, engine temp, outside air temp coolant tem, and ect. the most important factor is ac. when ac is on idle needs to be raised this is done by the iac valve. computer senses this and idle is raised with out iac w/ac the car might stall out, and or run abnormal idle.
