sidewayzpimpn
Well ill start with the setup
Ka24de stock
T25 setup off an Sr
Apexi safc2
Plx wideband
S15 injectors
Xtd 6 and exedy pp
Maximal e60 maf setup 4in and 5out on the safc
255 walbro
Stock fpr
Ngk bkr7e gaped to .35
Cxracing front mount
And my exhaust cuts off at the resonator
Well the car is super hard to start and when It does it idled like crap when cold and I have to mess wither the afc to get it to idle higher and when i let off the gas it goes straight to lean and pops like crazy. Now when i cruise it drives great and goes well into boost :bigthumbbut when its at idle I have cylinder #2 and 3 are dead when i pull the wires. I checked the compression and i have 83 in #1, 53 in #2, 58 in#3 and 89 in #4. My plugs are black as hell in those two cylinders and i don't think I have an intake leak cause I cover the maf lightly and it shuts off right away. I have used seafoam yesterday and i really don't feel much a difference. The cylinders only die at idle though cause when i hold the revs up and pull the wire it sputters. It's not tuned or anything but I want to at least get it idleing right so I can get it dyno tuned. Could it be bad valves seats , heavy carbon build up? Any help or ideas are great Im at my last resort to pull the head and do a valve job. Thanks in advance.
Ka24de stock
T25 setup off an Sr
Apexi safc2
Plx wideband
S15 injectors
Xtd 6 and exedy pp
255 walbro
Stock fpr
