AR
Banned
Workout tips :
a typical guy's stale routine: treadmill for 5 minutes, then bench presses until someone asks if he's almost done—in which case he's suddenly on his last set. Next, a few rows, curls, and crunches, then a quick toe touch and he's out.
You can do better, beginning with your warmup. "Most men warm up with a few minutes of light cycling or jogging," says Brad Jordan, NSCA-C.P.T., a personal trainer in Dayton, Ohio. And that's fine if all you plan to do in your workout is lower-body exercise. But an upper-body workout demands something that's more in sync with your plans. "Switch your warmup to jumping rope, rowing lightly, or using any cardio machine, like an elliptical trainer, that makes you pump your arms," Jordan says.
As for the rest of your routine . . . stop calling it routine. Refresh it, and yourself, with these moves.
Start with Your Hamstrings
"Most men do the exercises they like first and save the ones they know they hate for last," says Steve Lischin, NASM-C.P.T. "Toward the end of a workout, they either put little effort into these exercises or just skip them entirely." Performing your workout in the opposite order can give muscles you tend to overlook (such as your hamstrings) the attention they deserve. And saving your favorites for last can help you recharge when your energy level is in decline.
Stretch Between Sets
"Don't stretch only when your muscles feel tight," says Jordan. Stretching the muscles you're working not only helps them stay loose, but can also increase your range of motion, allowing you to work more muscle fibers with each additional set.
Take a Coffee Break
Anytime you draw your legs toward your midsection—reverse crunches, V-ups—you emphasize the lower portion of your abs. These moves also stress your hip flexors, the muscles on the front of your thighs. When these muscles are involved, your abs exert less than full effort, and you end up with tight hip flexors.
Overcome this tendency by pretending there's a cup of coffee resting just below your belly button. Before bringing your legs up each time, imagine tilting that cup toward your legs first. "This redirects your body positioning, so the effort stays concentrated on the lower abs," says Len Kravitz, Ph.D., coordinator of exercise science at the University of New Mexico.
Close Your Eyes While Exercising
This helps you visualize the muscles you're working, which is especially helpful for posterior muscle groups like your back, hamstrings, and butt. (Exceptions allowed when that brunette happens by.) Also try closing your eyes during any exercise that involves balance, such as a one-legged squat. "It challenges the neuromuscular system and helps you establish better balance," says Carter Hays, C.S.C.S., a Houston-based personal trainer. "It's actually harder closing just one eye than both eyes; it's weird."
Change Your Inclination
Rather than do three sets of dumbbell presses followed by three sets of incline presses, combine the two exercises. Start with one set of chest presses on a flat bench. Then raise the bench one notch from the flat position—to about 15 to 20 degrees—for your second set. Continue raising the angle one notch per set, stopping at the notch before vertical. "This lets you exhaust more muscle fibers by working your chest through five or six different angles instead of just the basic two," says Wayne Westcott, Ph.D., a Massachusetts-based exercise researcher. You'll actually end up doing fewer sets, so you'll save time, too.
Get Twisted
During the standard single-arm dumbbell row, your palm faces in as you raise and lower the weight along the side of your chest. To get more out of the move, rotate your wrist inward 180 degrees as you lower the dumbbell so that your thumb ends up pointing behind you when your arm is completely straight. This rotation helps adduct the scapula, working the back through a fuller range of motion for added strength and size.
Stop and Go
Instead of raising and lowering the weight in one continuous motion, pause for a second about halfway up, continue the movement, and then pause again about halfway down. "In a set of eight to 12 repetitions, you'll add only an extra 16 to 24 seconds to each set, but you'll be able to exhaust your muscles faster using less weight," says Lischin. This tactic works great with shoulder presses, lateral raises, and bent-over lateral raises.
Lower the Weight with One Leg
Your muscles are much stronger during the eccentric phase of an exercise—when the weight is being lowered. With leg presses, leg curls, and leg extensions, consider the "two up, one down" option. Try pressing or curling the weight up with both legs, then slowly lowering the weight back down using only one leg. This lets you work your muscles even harder in the same amount of time without constantly needing to change the weight, says Westcott.
Spread 'Em
Change your hand spacing with each set of barbell curls, instead of keeping them placed at shoulder width for all you repetitions. "Spreading your hands a few inches farther out stresses more of the inner portion of your biceps, while bringing your hands in a few inches builds more of the outer part," says Lischin. Or, try switching from the standard shoulder-width grip on a barbell to an angled position with an EZ-curl bar.
Run the Rack
Save time on the last dumbbell exercise in your workout. Instead of doing three sets of shoulder presses, biceps curls, or any dumbbell move, start with a weight that's about 50 percent of what you usually use to do 10 to 12 repetitions. Perform the exercise six times, then quickly grab the weight that's one increment heavier. Continue working your way up in weight until you finally find one that you can't lift six times using proper technique. Then reverse this process by grabbing a slightly lighter weight and completing as many repetitions as possible, even if you can only manage a few. Keep moving down the rack until you're left using the lightest set of dumbbells possible.
Some myths and flaws :
Fitness Flaw: Going at three speeds hard, harder, and I'm gonna pant like an overheated Irish wolfhound.
High-intensity, high-impact aerobic activities can be great for calorie-burning, but not for joint-saving. "Constantly pounding the body with high-intensity exercise often won't give your body an adequate amount of recovery time. That can result in you reaching a plateau or worse, an overuse injury," Dr. Bryant says.
The Fix: Limit anything that has a lot of jumping, bounding, or repetitive stress (running, boot camp classes). And don't push your heart rate up to 90 percent of your maximum (estimated as 220 minus your age) more than 2 or 3 days a week, particularly if you're doing high-impact activities. Instead sub in swimming, walking, elliptical trainers, resistance training, or rest. "Signs you're overdoing it include muscle soreness lasting more than a day or two, fatigue lasting more than a few hours after a workout, frequent injury, loss of motivation, and increased or decreased appetite," Huehls says.
Fitness Flaw: Making stretching the first thing you do at the gym.
For years people thought preworkout stretching was essential to prevent injury. But cold muscles are like uncooked noodles; they need to be heated up before they can move freely. "We now suggest you don't stretch before you work out because it doesn't appear to reduce the risk of injury. It may even lead to injury and compromise performance," Blahnik says.
The Fix: To warm up before a workout, skip stretching and do 5 to 10 minutes of cardio or a lighter, easier version of whatever movements you do in the workout itself. But don't ignore stretching completely, because muscle flexibility will relieve overall tightness and reduce injury over the long term. You can focus on traditionally tight areas like your hamstrings, but don't ignore the most neglected muscles: your back, neck, and feet (common areas of tightness for women who sit at desks or wear heels). To prevent neck strain, for example, do this full-motion stretch 10 to 12 times on each side using slow, controlled, fluid movements: Stand with your feet shoulder-width apart and, keeping your chin up, turn your head as far to one side as possible, then turn back to the opposite side, and repeat.
Fitness Flaw: Speeding through your workouts to raise your heart rate.
Moving quickly through your sets may help you make it back in time for Oprah, but it could also be a sign you're misusing momentum, executing the exercise incorrectly, or using too much or too little weight. Many women tend to use momentum with crunches, potentially straining the neck, says Janet Huehls, clinical exercise physiologist for the weight center at the University of Massachusetts Memorial Medical Center. Another momentum temptation: lunges. Speeding through them increases the risk of pulled muscles or joint strains and sprains.
The Fix: With any strength move, go at a slow, controlled pace in the lifting and lowering phases (2 seconds up, 2 seconds down). "There should be no point at which you pick up speed," says California trainer Jay Blahnik, author of Full-Body Flexibility. With crunches, hold dumbbells or a medicine ball on your chest to slow you down. For lunges, hold a dumbbell in each hand as you perform your reps or try doing them with your front foot on a Bosu balance trainer. (If you want to raise your heart rate during circuit training, decrease the time of rest between exercises rather than rushing through the exercise.)
Take a Coffee Break
Get Twisted
Stop and Go
Spread 'Em
Run the Rack
