dori dori said:Lower offset DOES NOT necessarily = "better handling". Creating a wider stance should increase stability, but then the driver will have to deal with a change in scrub radius. There will also be increased stress on your wheel hubs from running a lower offset wheel. Anyway, a good thing to remember about adjusting anything suspension related on your car...there are usually ALWAYS compramises that must be made. Can you deal with increased tire wear? Sluggish turn-in? At the limit understeer? Snap oversteer? Ect. Ect. Ect.
e30 gangsta said:this should be stickeyed.
dori dori said:Not really since much of the info is CRAP.
ProjectRB26DETT said:I've contemplated throwing an ABS on my 240 several times allready... It kinda kills the joy of wet weather driving in the S13 when you have bald tires, step on the breaks and find your car skidding forward.The lack of ABS can be an issue here in florida (or atleast I find it to be one).
I imagine that ABS isn't a problem in a drift car but i might be wrong. Does ABS affect the vehicle in any way during a drift? I know that there are instances in wich the driver has to apply the breaks. But does the fact that the tires dont lock up have any negative effects on the car while drifting?
If not, has anyone actually ever seen an S13 with ABS from factory? I've reasearched prices for several components for the S13 and at times i find the "S13 w/ABS" part added in under Vehicle Selection. I myself have never seen an S13 with a factory equipped ABS system. Has anyone else here?
ProjectRB26DETT said:Well by all means dori, provide some better information... Not flaming, just want to learn all i can. If you dont have meaningful information to provide, then plz dont flame what others have posted.![]()
Piner said:ofcourse im not talking about in excessive amounts of either positive or negative offset but it can make a difference. Its not much but I just felt that it needed to be stated that there is a slight performance advantage to a wider stance
S13 Grip said:My settings are Front camber 2.5-3 degress and the rear .5 degree
and when i get some damn shocks, it would be 8 way adj maybe so 4F and 6R with springs rates 8-6
Front Caster -1 Degree R Stock and Toe i leave at stock since i still daily my car....of corse these are my drift settings
daily woul dbe .5 Camber Front and Rear
dampening would be probly 2 front and 4 rear
everything esle stays the same.
dori dori said:For a novice, you won't even go through 1 set of rears in 3 events so don't worry about taking so many tires.
What you listed is good for an event...it's pretty common to lose a lug or break a stud, so if you have any extras of those, bring em. Tire pressure gauge is good to bring. Some extra cash too. I can tell you one thing you should never, ever bring to an event though...your "pride". Leave it at home and come with an open mind. So many novices take long amounts of time to improve because they have too much pride to ask for advice from other drivers or instructors. I'm a pretty decent driver but I'm always asking for advice, tips, or ride-alongs. After most drift events, at the end of the day I feel like I've learned something or gotten a little better...which is the purpose of a practice event.
