widest rim on an s13
I had a 15x10 -30 with a stupid roll.
Yes they are diamond race wheels
omg that camber up front looks ridiculously retarded.
I know I modified the lower mounts on the coilovers to adjust more camber because my top hats were only allowing me like -1 degree. I did that and set the camber all the way in because I had just finished with them so I said fuck it and drove to the meet. Like 2 days later I got the car aligned and it was at -3.3 after that. When I put the car on the rack with the top hats at full positive the front was at -6.6 so in those pics it was probably more along the likes of -8 degrees which is completely retarded.
in ur situation, a 215 up front isnt even a stretch i would say like 205..
So your saying a 215mm or 8.4" tire isn't a stretch on 9" wheels? I see .6" of stretch, depending on if the tire is actually 215mm wide and not smaller like triangles.
As far as 16x9 all around, people are running hotwheels which are 17x9+0 all around without pulling the fenders. And this is on 215-225/45 tires, with an azenis up front which actually runs 225-235mm.
If you go with 16x10s out back, Id go with a +10-15 not a +-0. Unless of course you want a serious pull, which doesn't look too great on s13s IMO.
I remember seeing the car dangle lol that was ridiculous, and you ^^ if they're running 17x9 +0 with a slight pull, a 16x9 with a smaller tire should leave me extra room, and just enough room for that extra half inch no?
